1 members (carbking),
160
10
Mod | | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41354 01/03/2005 10:45 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I bought a rebuilt fuel pump for my 55.1 so I would get the extra vac for the wipers. The fuel pump arm that rides the cam will wear. Someone told me I should put a sacraficial wear plate or shoe on the fuel pump arm to eliminate the potential for wear on the cam. Is this realllly necessary??? Thanks - Scott
55 1st Chev.
#41355 01/04/2005 7:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Usually the diaphragm wears out on the fuel pump long before the follower does. I wouldn't do anything, it gets oiled, and has less force on it than a valve lifter. You don't worry about your valve lifters wearing out, do you? Besides, if you put something on there and it shreds up it ends up in the oil.
#41356 01/05/2005 10:51 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for the comments....makes sense to me. I appreciat the informed take on it. - Scott
55 1st Chev.
#41357 01/06/2005 12:30 AM | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Speaking of fuel pumps - can the diphragm be replaced easily, or is a new pump the best route to go when the diaphragm goes? Mine is seeping a bit at the edges, but is not getting in the oil yet. I check the oil on a regular basis - it is not thin nor does it smell of gas - yet. BW | | |
#41358 01/06/2005 3:18 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | The diaphram is easy to replace, but finding one is a little difficult. They're not that cheap really ($19 or so), and I wonder that if I bought one - perhaps it's been on the shelf for several years.
So I think a rebuild pump is a safer bet overall. However, if you bought a rebuild kit in decent shape - and keep the diaphram in good condition with silicon spray, it would be good insurance on a long trip. | | |
#41359 01/06/2005 3:23 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | When I had my fuel pump off I found it was pretty hard to operate. I thought it was normal, but you say it should move pretty freely?
54 3100 with 235 62 flatbed dump C60 with 261
#41360 01/06/2005 6:55 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The pump has a pretty stiff spring in it. Hard to move by hand.
Also, you can buy pumps for these trucks at a mom & pop parts store. When I bought a new pump for my 235, they had 3 options. No sediment bowl, with bowl, and with bowl and vacuum pump. They had all three on the shelf. Can't recall the exact price, I think the vacuum pump model was around $60. And these wre new pumps, not rebuilds.
Fred 52 3600 69 C-10
