2 members (Otto Skorzeny, BC59), 259 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
#410579 05/07/2008 8:19 AM
Has anyone an idea how to repair that broken spring? The rest of the spring is at hand.
Thanx in advance!
AJ
[IMG]http://img99.imageshack.us/img99/488/1000333kh9.th.jpg[/IMG]
'59 Apache
'67 Mustang
AJ, i have a 57 witht he same problem, but 2 broken springs. one like yours and the other broken close tot he circle spring part or it.
i am going to get some rod the same diameter, overlap in both directions, then lightly mig or tig them together.
i have heard from another member here on the bolt that you could also get some donor rod, overlap, tie up tight with tie wire, and JB weld them together. he said that worked like a charm.
hope this helps.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Hi Leonard,
your solution was my inspiration. Thank you very much.
[IMG]http://img132.imageshack.us/img132/5901/1000365seq7.th.jpg[/IMG]
AJ
'59 Apache
'67 Mustang
no problem AJ.
i actually like your idea better than mine. LOL.
gonna see how mine works for about a month, and if i dont like it wil try your idea, then recover.
where did you get that spring from ?
leonard
I am sure yours will work too!
I bought the spring in a common hardware store for € 1,30 (less than 1 $). The resistance is almost as strong as on the other side.
I will post a pic when it is complete.
AJ
'59 Apache
'67 Mustang
thanks AJ.
didnt realize you are in germany. LOL.
yea, please post a pic of the seat, and especially your truck man. i really want to see it.
thanks again.
leonard
Moderated by  ndkid275, Phak1
