3 members (TUTS 59, greenie-reddy, Youngin' Tut 59), 56 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#41313 10/19/2004 11:51 PM
I've had two different Rochester 1-bbl carbs on my 216 and both of them have behaved this way. The needle valve sticks and causes flooding. If I pound on the fuel inlet area, it frees up the needle and everything works fine. I've had the top off the carb a number of times, removed the needle and seat, cleaned everything out, even reamed it a bit to give a little more clearance, but the problem persists. Any ideas?
Carburetion specialist
If you start the vehicle infrequently, the varnish residue formed upon the evaporation of modern fuel can cause this problem. Solution - have more fun - start the vehicle daily.
Jon.
The Carburetor Shop
Any rubber lines in the fuel system? Seems that when they get old, the insides deteriorate and punish you with little black chunks that find their way to the needle and seat. I went to the gross-jet needle and seats described in the tech article on multi rochesters on inliners site. They have been very reliable so far.
