6 members (MNSmith, jfjbjr, Southerntruck, Gray_Ghost, Otto Skorzeny, wilbur53), 163 guests, and 1 robot.
Topics128,080
Posts1,056,062
Members48,433
#41298 06/12/2002 11:20 PM
There is a post on this site that gives a procedure for replacing both halves of the old wick style rear main seal with the crankshaft still in the engine. I am asking how many have actually successfully done that. I have done the neoprene ones on the 261, 235 and the 194 but not one of the old ones.
1951 1 Ton Completed
#41299 06/13/2002 9:13 AM
Oly Offline
truckernix, It works!! I wrote the tech tip on it and , it is, virtually "blonde proof". If you follow the instructions as written it works like magic. You will be pleased I'm sure.
ps
Use the NOS with asbestos.
Oly
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#41300 06/13/2002 5:26 PM
Oly,
thanks. Is there such a thing as a seal puller or pusher ? I have heard the term used in this regard but I don't know if this is a homemade gadget.
Fred
#41301 06/13/2002 6:25 PM
Quote
Originally posted by truckernix:
Oly,
Fred
Bend a piece of brass rod. I've even used #9 wire. A rubber seal that I bought years ago for a 250 had one with it, but I don't think you get them anymore in today's cost-conscious world.
Fred
52 3600
69 C-10
#41302 06/14/2002 12:44 AM
thanks for the replies. This sure beats pulling the engine out just to replace the seal.
Fred
#41303 06/14/2002 5:51 AM
I usually just use the old seal to push the new one in! Guess that's not possible with rope...
The 250 seals do come with a specially shaped piece of plastic so that you don't damage the BACK of the seal when inserting it.
I always use stuff like that because you know if they spent the extra $.03 to include it, it must be because the had to replace a million seals for being faulty... wink
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#41304 06/15/2002 1:01 PM
KD sells an oil seal remover and installer. http://www.mytoolstore.com/kd/kdengi04.html#492
Jim
#41305 06/15/2002 1:59 PM
Thanks for the information. Having the actual tool will probably be an advantage.
#41306 06/15/2002 4:11 PM
My local NAPA stocks the installer/remover kits for about $25 if I remember correctly. Remover looks like a threaded ice pick. Installer works like a Chinese finger. jerry
#41307 06/16/2002 12:46 AM
Boyoconnor,
the first neoprene one I did, I peeled a good chunk of rubber off the back and I had to go get another one. I would not have guessed that the machined block could be so sharp !
