4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#412 07/22/2004 10:56 PM
I have a 235 1955 and want to check the vacuum advance. Does anyone know how you do this? I appreciate any help.
#413 07/22/2004 11:05 PM
If you want to see if it moves use a hand held vac. pump and watch the point plate.It will pull toward the vac adv pot.Or if you want to see with it running put a timing light on it and run it up to about 2500 rpm and pull the vac line off and see how much the timing retards.
MIke
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
