8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Are all AD and TF 1/2 ton front hubs the same? | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Tim,
Thanks this is what I need. I should have checked some catalogs for the years of bearings. I did not think of that. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I tried an extra hub from my 55 2nd on the spindle that is on my 53 and it was too big. I do know that the front end/spindle is from an earlier model because it had Huck brakes. I would like to change over to bendix. That is what is on the rear of this truck.
I do not understand? Do I need to change the spindles and hubs?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Does anyone know if the spindles are different sizes in the ADs with huck brakes and the newer bendix brakes?
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The hub and bearings are the same for 47 thru 59. This would tell me the spindles are the same as well; that is, as they relate to the bearings and hub. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you Lonnie,
I just bought the backing plates from Jimbo. All I need is one more hub to finish my front end switch to bendix.
Cool
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | According to the conversion procedure by Mike Klepp, the spindle is the same.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Tom. Thanks.
This is even better information. I did not realize the hubs from my old hucks came free from the drums.
The article said to use these old hubs. Great.
Now I have everything.
Thank you.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Darn, just when I feel like things will move forward a wrench is thrown in the works.
Last night I went out to the shop. I shelf had fallen off the wall. The one with all my buckets of nails. And my air tools. And glass things. Poop.
After I cleaned that up. I got a spindle from the 55 2nd and a drum from the 'original' front end. The 'original' is something like a 50 that had the huck brake. I have not taken it apart like what is written earlier.
The hub from the 55 is long and the holding bolt does not go all the way on. The 'original' hub/drum is together and to take it apart will require all the studs be pressed out then there will be the hub, drum, and inner plate.
Question. If I either press the studs out with my vise or have them hydrolically pressed - do I put the inner plate on the hub before I press the studs back on? Will this work and the hub fit so I can change it over to Bendix brakes?
Anybody have the experience in doing this?
TIA
