4 members (3800GUY, 3B, JW51, Lightholder's Dad), 125 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
Junior Member
Junior Member
I swapped the old rear with one from a 72 Blazer. The driveshaft is 2 inches too short. I found an extended slip joint from a driveshaft site on the web that would give me the extra lenght. My question is is this the better way to go or should I have a piece added by a qualified shop?
Well since no one has jumped on I will.
Mack Welcome to the Board!
If it were me I would have the drive shaft lengthened and welded.
Good luck and keep us posted.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Gidday Mack , go with the new ( extended ) driveshaft . The shop will cut your U joint ends off the old shaft and fit them to a new tube , of the length you specify , balance it too .
Mack, how does the diff' fit on the ol'53?
Is it close in width? What trans are you running?
Inquiring '53 owners want to know!
rick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
