5 members (3B, carbking, Bill Hanlon, Cletus1950, dt235sd), 73 guests, and 3 robots.
Topics128,181
Posts1,057,177
Members48,465
jdl
Offline
How do you get the dash light bulbs out so?
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Ex Hall Monitor
Ex Hall Monitor
I believe 54s still have them mounted in a socket that just pushes into a hole in the dash. Grab the back of the socket & wiggle it as you pull it out. Once the socket w/bulb is out push the bulb into the socket while turning counter clockwise on the bulb. It'll turn a few degrees then pull straight out. If I'm wrong I'm sure someone will point it out. grin
jdl
Offline
Thanks and I just noticed something about my truck! Look in the GT forum.
Jordan D. Long
Photobucket
jdl
Offline
Well, you were right. Got them out(how many are there?) but I can't replace one of the sockets into the hole, not that it matters right now since I don't have the bulbs.
Jordan D. Long
Photobucket
Ex Hall Monitor
Ex Hall Monitor
If the "ears" that hold the socket in get bent out a bit too far it can make it difficult to get the socket back in. You'll get the hang of it.
jdl
Offline
Yep, I was going to try to pull them in a little but that will have to wait for tomorrow. Too bad I couldn't just stick one box(that reduces the power to a constant 6v) in the power line from the starter instead of having to change out all of them good bulbs!(No big deal but I wish I could put them to use, they all work courtesy of testing with a 6v flashlight battery, but they won't work in the flashlight itself)
Jordan D. Long
Photobucket
Why couldn't you put a reducer in the line from the main light switch that feeds the dash lights if you really wanted to keep those 6v bulbs?
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
jdl
Offline
Well, technically, I could do that but right now I'm just thinking of going and getting a 6v battery. Won't hurt anything to get it to check everything out and if everything is fine like someone else said "why mess with success?"
Jordan D. Long
Photobucket
