| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 18 New Guy | | New Guy Joined: Jun 2005 Posts: 18 | I've read posts and instructions from the manual as how it is necessary to add about a cup of 90w into the ball housing after reassembly to provide initial lubrication for the u-joint assembly. As I understand it, once the truck is running, tranny lube passes through into the ball housing to provide continual lubrication for the u-joint. Does this mean that the transmission is continually losing 90w and if so, how often should I be checking that level? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Well, jd, the quick answer is "yes" you will most likely always be loosing transmission fluid; either from dripping-by various external gaskets and seals, or by passing-by the driveshaft/torque-tube bearing/bushing.
However, if your seals and bushings are good, the loss is minimal. Just check (and, top-up) the level of the transmission fluid every time you change oil (3,000 miles?), unless you see a lot of transmission fluid dripping under the truck (then, top-up more often).
Tim | | | | | Joined: Jun 2005 Posts: 18 New Guy | | New Guy Joined: Jun 2005 Posts: 18 | Thanks Tim, that makes sense. Gotta love those torque tubes... | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | One of my biggest nightmares was checking the tranny to find it dry and the differential more than full. You guessed it - the seal in the torque tube had failed which necessitated installing an Okie assembly - a job I would not want to do again. Even today, three years later, I am checking my tranny fluid after every ride. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | When I had my jeep with a leak that kept coming back, I made a sight glass for the transmission- I replaced the drain and fill plugs with pipe nipples and ran a length of clear tubing between the two. It made it really easy to check, I would just look under there with a flashlight.
