0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#410728 05/07/2008 10:49 PM
Well I went out to the garage in order to start the beast up and move it out so that I could start repairing the damage from the tree that fell crushing my garage. Then I noticed that the axle on the 52 1 ton is off center. Although I did not take out a measuring stick and drop a line it certainly looked that way. Now I had this discussion before about swapping out a ford rear end and people said there was a concern for the center axle vs the offset 9in. Were the axles off center? or should I believe that the axle was changed? Thoughts?
Is the 1/2 ton centered?
