1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#411116 05/08/2008 11:24 PM
Hi all, Im a newby here and just brought home a project that I was told is a 40 but there is no vin info at all that I can find. The engine number on the pad behind the distributor is HAD1134808. Any info would be appreciated and I would be very interested in aquiring a suitable title and vin plate. Thanks, Ron
read this thread If you use the search link on the members toolbar at the top of the page, you will find a lot of information that will be helpful to you. Just type in keywords IE: engine identification, engine id, what type of engine etc. Good luck and welcome to the bolt!
Welcome to the Bolt, Ron.
I think I can help with your engine number.
All of the info I am using comes from the Keith Hardy site of "Old Online Chevy Manuals". http://chevy.tocmp.com/index.htm. GMONIZ already sent you there if you checked out his thread.
Using the resto-pack info for 1950 passenger cars,
http://chevy.tocmp.com/chevyresto/5008.htm I believe you'll find
"H" is the designation for engines built for the 1950 year.
"A" is for passenger car engines.
"D" is a Flint engine plant designation and refers to RPO (regular production option) 317
http://chevy.tocmp.com/chevyresto/5042.htm
the automatic transmission option (Powerglide) for the Deluxe Series 2100 models
http://chevy.tocmp.com/models/1950models.htm
I believe this engine was the 235 cu in and was the first year for the 235/Powerglide combo in Chevy passenger cars.
1134808 signifies the 1,134,808 engine built at Flint for that year.
Don't know if you have a 1940 truck or not. Check out the gallery here at the Bolt and find one that looks like yours.
Be sure to post some pictures, everybody here loves old truck pictures.
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
