1 members (CuzzFuzz),
228
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | The fan belt on my '66 squeals at no matter what, when the engine goes about about 3300RPMs. Even when I tighten the belt or loosen it, it always squeals at the same rpms. I only have 3 pulleys on the belt and I assume that the large distance that the belt travels causes the squealing. I tried Gunk, it doesn't help at all. My fan belt is the V-type (or whatever it is called) that has more traction. Any ideas? Maybe a wide pulley set? Here is a photo, if that helps anything. Thanks | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would check your water pump and generator/alternator bearings, it sounds like something is siezing up.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dellman,
While V-belts can and do get glazed and loose their traction (permanently) it sure looks like your alternator is maxed out on the tension. How about one size smaller on the belt length...would that allow you to tension it properly.
If the belt has slipped long enough it cooks the friction surface and no amount of tension will save it. Things like Gunk can harden it too so it slips.
I sure would try a new, shorter belt and be sure to tension it properly. After a hundred miles or so, it will stretch and you will need to give it another oink.
Stuart | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | The possibility of bad bearings on the water pump is possible, it has sometimes made noises before although it spins easily when spun by hand. But I will try atomarc's suggestions, I don't think it is a warn belt as I had bought another one in attempt to fix the squeal and it did not help. The belt tension is maxed out so I will buy the next size down sized belt probably tomorrow, I will let you know the results. Thanks | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Also, very carefully check the alignment of the pullies with each other. Even a small offset can cause a belt to squeal.
1949 "Heinz 57"
It wouldn't hurt to clean the grooves on the crank and waterpump pulleys either. Brake-Kleen and a little sandpaper will give them a good new surface for the belt to bite on.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Stuarts suggestion might help, but I've found that older high mount position is very prone to squealing with an alternator, it may be the long travel .... prolly why they changed later to the low mount with shorter belts
Bill | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | try wiggling the fan blades fore and aft there should be no play... if there is the waterpump bearings are on their way out.... any spray on belt conditioner is short term fix and contamination, either oil or antifreeze will cause noisy belts also if the belt is too tight it will cause noise....pressing down moderatly on the middle of the belt between pulleys you should have 1/2-3/4" deflection only. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | get you a long wooden stick and probe around the alt or where you might hear the noise...you can pick up the noise real quick.. just stay out of the moving belts.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Looks to me from your picture that you're running too wide of a belt for the pulley grooves. The belt should set down flush with the top of the pulley while yours is sticking up past the edge.
If that's a 1/2" wide belt you're running I'd go with a 3/8 Gatorback and get rid of the belt dressing.....that stuff will kill a belt in a heartbeat. The Gatorback belts are a little more expensive but when you get the correct width and loose the squeal it will seem worth it!
Dave | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | I bought the next size down fan belt. I checked the bearings on the water pump and made sure that the pulleys were lined up. Next I clean all the old burnt rubber surface from the pulleys and installed the belt. The squeal is completely gone, even at 5,000rpms (high as I wanted to go). The problem is solved even though the alternator is very close to the valve cover now; I had to remove the cover to install the belt. Fla54Chevy3100, I noticed that the belt seemed too wide but I didn't read your post until after I bought the new belt but the squeal is gone now anyway. Anyway, thanks everyone for your help! | | |
