4 members (MikeE, lc_btv, Oldcaliforniakid, Rexville48), 104 guests, and 3 robots.
Topics128,050
Posts1,055,673
#410609 05/07/2008 2:35 PM
I had a SCARY thing happen yesterday I was winding up the ol gal a bit to check the kickdown, 4 barrell and such, hit a pretty crappy bridge that crosses the road not far from home and the hood popped open ...luckily the emergency catch caught it and kept it from flying up and causing ...WELL YA KNOW...soo my ?
I have replaced all the hood rubbers with new, how much SPRING should I have when the hood is closed and locked?
Right now I have to slam it pretty good to latch it wich I am now confident ISNT RIGHT, it is like rock solid when closed, with the spring on the hood pin Im pretty sure it should close, latch and have a bit of spring pressure to work with not be solid.
any help will be appreciated.
I do not have a service manual for my 52..Im winging it.
thanks
Tim
1952 Chevy Shortbed
Photos in Photobucket
I've had that problem also, usually when i have the bra on the front. I close the hood and then reach in and push on the release lever to make sure it's in all the way.
Sounds to me that you need to adjust the primary catch down some if you have to slam it that hard.
Without the bra on mine, a gentle push will lock the hood but I always push on the lever just to make sure.
I had also notice and replaced the spring on the lever because it seemed weak and streched out.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
wilbur #410748 05/07/2008 11:44 PM
I am assuming that yours has a latch handle that moves sideways to unlock the hood. I went through this on mine and I figured that it was too tight. Anyway, when the hood latches correctly, the handle retreats to something past center. If it doesn't latch correctly, it doesn't move all the way to that position, but the hood looks fine. In this case the hood can pop.
You really should get a manual. You will save yourself a lot of grief.
1951 1 Ton Completed
Yeah, it sounds like it is too tight and not latching all the way.
Paint & Body Shop moderator
Same thing happened to me Radial, The guys abouve hit it on the nose, at least that was my problem!!
Thanks for the Input Gents!
did some adjusting and now it seems to be fully latching nice and snug.
Thanks!!!
Tim
1952 Chevy Shortbed
