1 members (baldeagle), 103 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#410277 05/06/2008 1:50 PM
I hear T 5 transmission a lot. I believe it is out of the S 10 trucks. And is a 4 or 5 speed manual transmission.
Is there a 'T 5' automatic transmission that can be put in our old trucks with a floor shift?
TIA
Dennis
volvo makes a T5 auto
don't think it'll fit
Jim & Caroline
Riding in the Passing Lane
T-5 is a 5 speed trans with 5th being o-drive. It was made by Borg-Warner & used in many applications for light duty. The best one for swaps into these old trucks is the early 80,s to 87 S-10 pickups. For an auto-odrive the 700-4R is good for swaps. The best for that is from 87 to 90 chevs.
1972 Chevy c10 Cheyenne Super
The current favorite factory manual transmission to put behind a Chevy smallblock seems to be the T56. Stronger than the five speed T5, plus an extra overdrive gear. Lets you run low rearend gears yet still drive it on the highway with reasonable gas milage.
this is the responce I received from Phoenix transmissions about my 250 six cylinder:
If this is indeed a 1965 250 then any or our 3 or 4 speed GM automatics will bolt up to it. You will most likely need to fabricate a crossmember for the rear of the trans, install a flywheel for the automatic, some type of shifter and cooler lines and cooler. In addition, you will have to have a driveshaft made to the new length and yoke. If you are happy
with the rpm of your top gear then the PT350HD will work well, or if you want lower rpms look at the PT700R4HD. Let me know if we can help.
