| | | Forums66 Topics128,036 Posts1,055,452 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I hear T 5 transmission a lot. I believe it is out of the S 10 trucks. And is a 4 or 5 speed manual transmission.
Is there a 'T 5' automatic transmission that can be put in our old trucks with a floor shift?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | volvo makes a T5 auto don't think it'll fit
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | T-5 is a 5 speed trans with 5th being o-drive. It was made by Borg-Warner & used in many applications for light duty. The best one for swaps into these old trucks is the early 80,s to 87 S-10 pickups. For an auto-odrive the 700-4R is good for swaps. The best for that is from 87 to 90 chevs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2008 Posts: 4 New Guy | | New Guy Joined: May 2008 Posts: 4 | The current favorite factory manual transmission to put behind a Chevy smallblock seems to be the T56. Stronger than the five speed T5, plus an extra overdrive gear. Lets you run low rearend gears yet still drive it on the highway with reasonable gas milage. | | | | | Joined: Mar 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 37 | this is the responce I received from Phoenix transmissions about my 250 six cylinder:
If this is indeed a 1965 250 then any or our 3 or 4 speed GM automatics will bolt up to it. You will most likely need to fabricate a crossmember for the rear of the trans, install a flywheel for the automatic, some type of shifter and cooler lines and cooler. In addition, you will have to have a driveshaft made to the new length and yoke. If you are happy with the rpm of your top gear then the PT350HD will work well, or if you want lower rpms look at the PT700R4HD. Let me know if we can help.
