4 members (54farmtruck, klhansen, Rich'sToys, Southerntruck), 344 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
Hello All been a bit, been kinda busy with stuff.
I replaced my spark plugs satuday morning, I wonder if I used the right plug. I used AC Delco 45, this is what Napa said to use, and this is what came out of it. Anyway I gapped them all, I put them in, ran fine most of the day saturday and then started missing badly. Well last night I checked them all out, and number cylindr was almost as if it hadn;t been gpped at all, the elctorde and the tang were touching. Did I put the wrong Spark plugs in this or did I just goof up and not gap that one> I swear I did. ANyaway its runing fine now with the exception of I need a new vacumn advance, both the ones I had are shot. I have checked the usual sources, anyone else know of someone other than the mail order catalog guys?
Birge
Birge
1952 Cheverolet 3600
http://www.flickr.com/photos/bilge77/
You probably gapped it alright, but bent it when you were hunting for the hole.
Riding in the Passing Lane
There might have been a piece of carbon break up & fly around & bend the electrode. AC 45 are fine but I like to use the extended tip plugs on OHV engines.Like 45S. Did the Napa guy look for the vacuum advance unit. It seems like they would list it. There are 3 specialty stores in K.C. but I believe you are near the St. Louis area.
1972 Chevy c10 Cheyenne Super
Yeah Just Boaut an Hour South I looked on Nanps Website I will go by there after work. Maybe they have one. If not I guess I can get a one form the mail order guys. I am afraid of the ebayers and there NOS parts just because this is a rubber diaphragm and likely to be cracked or dry rotted.
Thanks for the Wrenchbender
Birge
