6 members (GIJOE298, TexasJim50, David Bush, Otto Skorzeny, Peggy M, 1955 1 Series), 82 guests, and 1 robot.
Topics128,154
Posts1,056,851
Members48,456
Is there a simple way to convert a long shaft water pump to a short shaft? If I take it to a machine shop, what dimension do I ask for?
Jim - It depends on what kind of pulley you will be using on the water pump and the space you have between the water pump and the radiator.
Joe smile
The procedure I used was:
Practice on the old pump. Get the pulley you need. I used a Ford pulley that fit exactly. Measure the difference in dish between the new and old pulley. Press the shaft collar on the water pump toward the engine in a hydraulic press. Install pump and pulley, see if it lines up. Cut off excess shaft.
Repeat on brand new pump from Napa.
Paint & Body Shop moderator
