3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#404260 04/19/2008 8:54 PM
Y
Y Offline
The ID plate on the door column of my door frame has been over painted some time in the past 55 years. What is the least destructive way to remove this paint and reveal the original ID plate?
Tempe, AZ
Bill S.
Tempe, AZ
YEL 53 CHEVY PU #404286 04/19/2008 11:11 PM
Apprentice
Apprentice
Swab it with brake fluid. Or, for something hotter, use laquer thinner. But watch out for spillage on paint you don't want lifted.
Laurence #404360 04/20/2008 2:05 AM
The I d Plate is painted already!!!!!!!!
If you use brake fluid u will have a blank
plate except for the no. stamped on it.
"Been there dun that"
I bought me a replacement plate and stamped my
existing no. on ot and installed it when I
finished painting my int.
I took my original plate to the auto paint store
and we tried all types of removers but they just kept
removing all of the paint including what I wanted to keep.
Not shure what to tell you but I hope this helps.
Good luck
bowtiesr4me #404399 04/20/2008 3:21 AM
Apprentice
Apprentice
I've not experienced that but if it has happened - chances are it will happen again. I suppose caution is the watchword here. Perhaps just trying it on a spot not having critical information on it will give you a feel for how to proceed carefully.
bowtiesr4me #409861 05/05/2008 6:40 AM
bowtiesr4me... where did you get your replacement plate from?
tpeerson #409931 05/05/2008 2:39 PM
Ex Hall Monitor
Ex Hall Monitor
I'm with bowties. Mine has been painted over and I found no way to remove the top coat without also removing the original paint. I also bought a repop data plate but don't have it on yet. If you really want to save the original you might try a painting conservator (those who clean & restore fine art paintings) and see if they can help you.
Tiny #410025 05/05/2008 9:55 PM
I just bought a repop plate and did like bowties said. Got my metal number and letter stamping kit out and put the original info back in. Even got some of the numbers a little crooked like the original.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
49 geezer #410047 05/05/2008 10:42 PM
Anyone please... where are you getting the plates from?
Thanks.
tpeerson #410098 05/06/2008 12:18 AM
Ex Hall Monitor
Ex Hall Monitor
Got mine on ebay. I don't know if they offer all years but Chevs of the 40s sells data plates & I think The Filling Station does too.
Tiny #410134 05/06/2008 1:44 AM
got mine from jim carters,got a 1/8" stamping kit from harbor freight for less than $10.00.good to go............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
david dyehouse #411473 05/10/2008 1:09 AM
Y
Y Offline
Managed to get ID plate cleaned enough to see that the stamped identification number ?? H53L002145.
My Kansas title for the truck indicates that the VIN is HAD58805. What's up? Any ideas?
Tempe, AZ
Bill S.
Tempe, AZ
YEL 53 CHEVY PU #411479 05/10/2008 1:32 AM
1 Offline
JASCO pait remover works great, it is controllable gel and mask off what you want to save.
John A Young
Moderated by  ndkid275, Phak1
