0 members (), 112 guests, and 3 robots.
Topics128,090
Posts1,056,380
Members48,442
Hi, Guys!
Finally coming down to the day where I'm going to spray a fender and a couple spots on dad's truck. I'm going to spray a single stage enamel on it and I need to use some hardener in it. The guy at my paint store told me he wrote down what ratio of hardener to use to product, but he lied--he didn't. And, since it's Saturday, they're closed. Does anyone know how much hardener I should use for a single stage enamel? Thanks!
google search your paint brand. they probably have a section on all the specs,ratios and tips
1948 Chevrolet 1.5-Ton
Should say on the label. With PPG, its 8:6:1 ratio of paint, reducer, hardener.
Bill Burmeister
Depends on the PPG product. The line I use is 4:1 paint to activator.
I use PPG Delstar. I only used it as an example. Best would be to check with the manufacturer for the exact mix for the product line.
Bill Burmeister
0
0 Offline
Get the product data sheet for the product you are using. You wouldn't drive crosscountry without a roadmap would you? The data sheet includes spraying tips, pot life, and various reducers for varying temperatures. Good luck.
Joe
