0 members (),
112
Mod | | | Forums66 Topics128,090 Posts1,056,380 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 48 | Hi, Guys! Finally coming down to the day where I'm going to spray a fender and a couple spots on dad's truck. I'm going to spray a single stage enamel on it and I need to use some hardener in it. The guy at my paint store told me he wrote down what ratio of hardener to use to product, but he lied--he didn't. And, since it's Saturday, they're closed. Does anyone know how much hardener I should use for a single stage enamel? Thanks! | | | | | Joined: May 2006 Posts: 16 New Guy | | New Guy Joined: May 2006 Posts: 16 | google search your paint brand. they probably have a section on all the specs,ratios and tips | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Should say on the label. With PPG, its 8:6:1 ratio of paint, reducer, hardener.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 4,253 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,253 | Depends on the PPG product. The line I use is 4:1 paint to activator. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I use PPG Delstar. I only used it as an example. Best would be to check with the manufacturer for the exact mix for the product line.
Bill Burmeister | | | | | Joined: Mar 2007 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 64 | Get the product data sheet for the product you are using. You wouldn't drive crosscountry without a roadmap would you? The data sheet includes spraying tips, pot life, and various reducers for varying temperatures. Good luck. Joe | | |
