| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I installed a Heidts IFS and firewall mounted power brake assembly on my 51 Ran all new brake lines everything BUT... Does Anyone know why the brake caliper is hanging up ? It stops fine but I can hear it squealing lightly and its burning up the pads ? In fact the wheel is covered in brake dust ?
It's always something...
Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | could be a bad hose or an internal problem in the caliper itself.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Improper master cylinder, proportioning valve, or mixed up plumbing, and as a result something is holding a little pressure in the line? My first thought is a residual pressure check valve built into the master cylinder, and intended for drum brake system, but that is just a guess.
When it does this, can you crack the bleeder screw and get any fluid?
Grigg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Good points, Grigg. That brings up a question. Both front brakes are hanging up, or just one?
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Very good points Grigg, It seems like its just one (right side) Bill... BUT I had brake dust on both wheels, It could be the proportioning valve. When I got everything I was welding and grinding at the frame only to find the proportioning valve laying in the floor covered in dirt and metal shavings from all the grinding I thought I had cleaned it good enough but...
I'll check it at the bleeder screw to see if there's any fluid the next time I take it out...Very good point on the proportioning valve, I just hope it's not the master cylinder.
Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Ditto the proportioning valve!
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Todd, I dont know what brake kit you bought, but I bought mine from Speedway. Turns out the calipers are 'rebuilts'. Check you dont have a 'sticky' piston and that your flexi lines aren't kinking when you turn the steering. If both were hanging up,both wheels would get pretty hot real quick.Just a thought...For disc brakes your proportioning valve should be 2lb. just in case you've been sent the wrong one!  Hope this helps. Jock  Correction I meant residual valve!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Yea I think before I do any damage Im going to order a new proportioning valve just to be safe. Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I Finally got the problem figured out with my front calipers hanging up, Some one told me that "I did not have the master cylinder cleaves rod adjusted correctly. I had to shim the master cylinder from the booster to get the correct clearance. The weight of the pedal was enough to heat the brakes up". AND IT WORKED !! So now that I know what it is, Im going to remove the master cylinder and try to adjust the cleaves rod... or I might just leave the shims in and call it done.  Thanks Ted !!! Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Call it done Buddy! I'm sure Mama has "stuff" for you to do"!
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Glad to hear you've sussed it out Todd!  There's nothing worse when you get your ride on the road,and something spoils the moment! :mad: Jock. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Yeah but there's still a problem, The Power Booster is bad but at least it's not dragging anymore AND that gave me a reason to get a new chrome one ! So it all worked out in the end ! Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
