0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#409426 05/04/2008 12:17 AM
1 Offline
I installed a Heidts IFS and firewall mounted power brake assembly on my 51 Ran all new brake lines everything BUT... Does Anyone know why the brake caliper is hanging up ? It stops fine but I can hear it squealing lightly and its burning up the pads ?
In fact the wheel is covered in brake dust ?
It's always something...
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
could be a bad hose or an internal problem in the caliper itself.
Bill Burmeister
Improper master cylinder, proportioning valve, or mixed up plumbing, and as a result something is holding a little pressure in the line? My first thought is a residual pressure check valve built into the master cylinder, and intended for drum brake system, but that is just a guess.
When it does this, can you crack the bleeder screw and get any fluid?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Good points, Grigg. That brings up a question. Both front brakes are hanging up, or just one?
Bill Burmeister
1 Offline
Very good points Grigg, It seems like its just one (right side) Bill... BUT I had brake dust on both wheels, It could be the proportioning valve. When I got everything I was welding and grinding at the frame only to find the proportioning valve laying in the floor covered in dirt and metal shavings from all the grinding I thought I had cleaned it good enough but...
I'll check it at the bleeder screw to see if there's any fluid the next time I take it out...Very good point on the proportioning valve, I just hope it's not the master cylinder.
Todd
Ditto the proportioning valve!
~Jim
Todd, I dont know what brake kit you bought, but I bought mine from Speedway. Turns out the calipers are 'rebuilts'. Check you dont have a 'sticky' piston and that your flexi lines aren't kinking when you turn the steering.
If both were hanging up,both wheels would get pretty hot real quick.Just a thought...For disc brakes your proportioning valve should be 2lb. just in case you've been sent the wrong one! dang Hope this helps. Jock grin
Correction I meant residual valve!
More pix on Flickr.
1 Offline
Yea I think before I do any damage Im going to order a new proportioning valve just to be safe.
Todd
1 Offline
I Finally got the problem figured out with my front calipers hanging up, Some one told me that "I did not have the master cylinder cleaves rod adjusted correctly. I had to shim the master cylinder from the booster to get the correct clearance. The weight of the pedal was enough to heat the brakes up". AND IT WORKED !!
So now that I know what it is, Im going to remove the master cylinder and try to adjust the cleaves rod... or I might just leave the shims in and call it done. grin
Thanks Ted !!!
Call it done Buddy! I'm sure Mama has "stuff" for you to do"! grin
~Jim
Glad to hear you've sussed it out Todd! thumbs_up
There's nothing worse when you get your ride on the road,and something spoils the moment! :mad:
Jock.
More pix on Flickr.
1 Offline
Yeah but there's still a problem, The Power Booster is bad but at least it's not dragging anymore AND that gave me a reason to get a new chrome one ! So it all worked out in the end !
Todd
