| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40929 08/09/2004 5:55 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | The radiator overflow tube pukes coolant when the engine warms up. I have a rebuilt 235 c.i. with a new water pump and a new radiator but after about 4-5 minutes of running the coolant starts coming out of the overflow tube. I have removed the thermostat thinking that may have contributed to the problem. Any ideas? | | |
#40930 08/09/2004 6:38 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Are you overfilling the radiator? These radiators are designed to only be filled (when cold) to just above the tubes, about 1" to 1 1/2" below the bottom of the neck. I think there may even be a fill line on the radiator.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#40931 08/09/2004 7:37 PM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Frist thing to do is put the thermastat back in. Drill a 1/16 hole in the flange of the thermastat and this will allow the air to get past the thermastat. The STAT will help to regulate the flow of your cooling system.
When you fill the Radiator. When do you stop filling? Where is the coolant level when you stop filling it?
Next when you run/ drive your truck what temp is the gauge reading?
Are you using straight water or a mix of water and antifreeze?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#40932 08/09/2004 7:54 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I fill the radiator up to where the coolant is at the bottom of the fill tube, I can't see the the tubes within the radiator a 1953 GMC. I tried the 1/16th hole in the flange of the thermostat and when the engine warms up it explodes out of the overflow tube so that's why I removed it. I don't have the gauge hooked up, I'll do that this weekend. I'm running a 50/50 mix of coolant and water. | | |
#40933 08/09/2004 8:02 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Buck, you got air in there somewhere friend. This works sometimes. Jack up the front of the truck some to get the front of the engine a little higher. Take off the top radiator hose and housing, take out the therm. Fill the head with a 50/50 mixture, then put in your 165 degree therm with the hole. Reattach your therem housing and hose to the radiator. Add a little more 50/50 and start up. Let truck down. Let it go thru a few heat and cool cycles over a period of a few days and check the coolant level. It will settle down. Oh yea put on a puke can. Sometimes it takes a little while to calm down and get all the air out.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#40934 08/09/2004 9:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s possible you have a head gasket leaking. Being the engine was recently built you might torque the head bolts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#40935 08/09/2004 10:36 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Well, I don't mean to challenge the other guys, but if you are filling to the bottom of the fill neck, you are overfilling. Does it stop puking out after a little bit? If so, leave it at that level and you should be fine.
Jeff Nelson
#40936 08/10/2004 12:56 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I aggree that it sounds like the radiator is getting overfilled. The level should be about 1 inche below the bottom of the filler neck.
This allows for the normal expansion for these radiators - the overflow bottle came later and called for totally filled radiators. | | |
#40937 08/10/2004 1:36 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I'm drilling my 'stats to 3/16" . I thinks 1/16" may be a little small to move much air. Hell most of my cooling systems got critters far bigger than a sixteenth inch. First one would trap the air in the head.  | | |
#40938 08/10/2004 2:02 AM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | I would agree that you are overfilling the radiator too. The colant should only go to the top of the fins within the radiator. That is about (guessing) 2" below the filler neck.
It is no wonder your truck is puking. The thermastat is opening up and then the water pump is pumping the hot coolant into the radiator and it has nowhere to go but out the overflow tube.
As for the hole in the stat 1/16 1/8 3/16. Anything is better then nothing.
#40939 08/10/2004 4:24 AM | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | i had the same problem in "truck vomits"  | | |
#40940 08/10/2004 5:01 AM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Change the radiator cap! Every pound of pressure raises the boiling point 3 degrees. Put a 180-degree thermostat and a puke can on it, and forget about a few dribbles! Jerry
#40941 08/10/2004 5:19 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Can you do a cylinder leakage test or cooling system pressure test. do the cooling system pressure test with the plugs out so you can hear the gurgling hiss on the cylinder that has the head-gasket leak or crack in the head,,,,,, go with the 180 stat and 50/50 mix like Hotrod Lincoln mentioned  . - If you do not have a head leak or crack, remove the radiator and have it cleaned
#40942 08/11/2004 7:06 AM | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | I had a problem with my firebird puking. I finally figured out that my fan wasn't pulling enough air through the radiator. same type thing happened to my dad's truck. he pulled the stat. still puked. everybody tried to tell him that he needed a new radiator. i found out that his fan clutch died. no more puke. may not be the case here. those systems should work well as designed. i don't believe it should need a drilled out stat. verify that you have proper air flow through the radiator before you start banging and drilling everything. just a different idea. hope you get it figured out.
#40943 08/11/2004 7:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The drilled out stat is necessary because the originals were, the replacements aren't. It lets a little water flow in the head to keep it from getting air locked.
