8 members (Ponchogl, Gabes-trucks, Wickedbass, Otto Skorzeny, 52Carl, dt235sd, BC59, 1 invisible), 138 guests, and 1 robot.
Topics128,081
Posts1,056,076
Members48,434
#408963 05/02/2008 4:37 AM
My 59 Apache SM420 has no speedo cable coming from it. Is the big bolt on the drivers side of the box near the top where the cable should be housed? Is there a special mount or is it a plug in? Thanks
~ Rasman
1971 Chevy C10
"Old Yeller"
Saga: "'Old Yeller' ... More than a Pristine 1971 Chevy"
1959 Chevy 1/2-Ton
In the Legacy Gallery
Riding in the Passing Lane
It is on the drivers side near the rear a little above where the yoke goes in. It has male threads with a square hole in the center. The large end of the cable screws on to it after the cable core goes in the hole.
1972 Chevy c10 Cheyenne Super
Okay thanks. I will be crawlin underneath and begin to scrape. Appreciate the info.
~ Rasman
1971 Chevy C10
"Old Yeller"
1959 Chevy 1/2-Ton
I have the same tranny in my '49 but the original speedo cable doesn't seem to want to thread on, so I don't know if we have to get a diff cable or what.
They big end was the same for many years. If it doesn't screw on the threads are stripped or the collar is out of round.
Keep in mind that if you have replaced the rear end gears with something other than original gearing, the speedo will not be accurate. Thus an adapter between the cable and the collar might be required. These adapters are generally custom calibrated and fitted to the tranny.
This is what I had to do when I installed Patrick's 3.55's in mine.
Craig
