Checked the forum, but didn't locate any specs on the holes, I need the specs because it appears my 216 was drilled also? It looks as if someone drilled a 2 series of four small holes holes so the carriage bolts would seat and not turn. Doesn't even look close to factory holes so I did not want to rely on this particular setup. The truck ,when running before, had a clanging when the clutch was engaged, checked the U-joint it looks ok, maybe engine was out of line? Will be replacing clutch,PP and turning flywheel, also checked rear end, looks OK.
By the way this was not the original engine, the numbers were ground off so I have no clue as to what size or year this engine is for sure. :confused:
Thanks for your help though!
Again, Any help is much appreciated.
