| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | My 59 Apache SM420 has no speedo cable coming from it. Is the big bolt on the drivers side of the box near the top where the cable should be housed? Is there a special mount or is it a plug in? Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is on the drivers side near the rear a little above where the yoke goes in. It has male threads with a square hole in the center. The large end of the cable screws on to it after the cable core goes in the hole. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Okay thanks. I will be crawlin underneath and begin to scrape. Appreciate the info. | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I have the same tranny in my '49 but the original speedo cable doesn't seem to want to thread on, so I don't know if we have to get a diff cable or what. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have the same tranny in my '49 but the original speedo cable doesn't seem to want to thread on, so I don't know if we have to get a diff cable or what. They big end was the same for many years. If it doesn't screw on the threads are stripped or the collar is out of round. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Keep in mind that if you have replaced the rear end gears with something other than original gearing, the speedo will not be accurate. Thus an adapter between the cable and the collar might be required. These adapters are generally custom calibrated and fitted to the tranny.
This is what I had to do when I installed Patrick's 3.55's in mine.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
