1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#40875 07/16/2002 10:29 PM
Joe
Offline
Junior Member
Junior Member
I'm in the process of changing out a leaking pinion seal in my 57 3100. The shop manual calls for measuring the bearing preload before disassembly so it can be matched after repairs. It recommends checking the torque with an in/lb torque wrench with one wheel free. My wrench starts at 20in/lb and the wheel will turn with less than that. So, the preload is too light to measure. The pinion does not have any excess play and no noise has been noticed. Should I just mark the nut and pinion and reuse the nut and forget about it, or how can I properly set it up with a new nut as recommended and get the proper preload? Thanks for any ideas anyone may have.
#40876 07/16/2002 10:42 PM
Joe, I have changed pinion seals like you said, mark the nut before removal and then reinstall with the same nut.I never had a problem afterwards so......
#40877 07/16/2002 11:20 PM
I have also done as Tony suggests .
It is REALLY hard to over torque the pinion nut when under the truck .
#40878 07/17/2002 2:58 AM
Hey Joe, I believe those two guys are onto something cool
#40879 07/17/2002 5:03 AM
Joe
Offline
Junior Member
Junior Member
Full speed ahead! Thanks guys.
