1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#40846 10/09/2003 2:15 AM
I
I Offline
I have three Eaton drop out third members. I am considering swapping the detroit locker in the 4.11 diff into the 4.57 diff or maybe even into a 5.14 diff. Do I need special tools or shims or whatever to do this? Do each of the R&P's need to be set up again? Or is this just a matter of putting stuff back the way I found it?
Usually when you change the carrier (which is what the detroit locker replaces) you have to set up the whole thing again.
Paint & Body Shop moderator
This is not so in these rear ends. I believe the Detroit locker parts will fit into the carrier you have. Please check with a reputable rear end parts supplier to be absolutely positive.
