| | | Forums66 Topics128,174 Posts1,057,047 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40831 12/07/2004 12:49 AM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | have an old Babbetted bearing 261 w/automatic. found a 68+ 250. wanting to do a swap. will it work? any hidden surprises besides motor mounts?
Benjamin P Lujin
#40832 12/07/2004 2:07 AM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Welcome May have ur engine nos transposed there--216s were babbit engines--261's were full pressure larger truck engines with insert bearings. The 250 engine has different mounting points than the earlier 216/235/261 engines and will require different motor mounts. Welcome to the board.
Buzz'n Half Dozen
#40833 12/07/2004 7:31 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | ok, but i read somewhere that the 216s didn't come with a factory automatic tranny mated to them and this one did. hmmmm, maybe it's a 235? i know the earlier models mounted up front with a plate behind the timing cover and late models were side mounted. will the front mounting plate bolt to the later model engines? will the tranny bolt right up?
Benjamin P Lujin
#40834 12/07/2004 8:35 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I assume this is a '50 3100. If that is correct, I don't think it was available stock with an automatic.
The early 50's cars with automatics had a full pressure motor.
What automatic transmission do you have?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#40835 12/07/2004 8:45 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | ok, this is a 1950 Styleline car. it has a babetted-bearing engine and powerglide automatic transmission. this i know without a doubt....i took it out myself. nothing looked modified to make me believe that any other kind of tranny has ever been in there. the engine's connecting rods do not have insert-style rod bearings. they are soldered/tinned in and one went bad.
Benjamin P Lujin
#40836 12/07/2004 10:06 PM | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | OK, now you're making more sense. This is mainly a truck forum, so we're not used to dealing with car questions. The automatic you've got is a cast iron case Powerglide, which won't bolt up to the later model engine. If you want to swap to the newer engine, you'll probably need to use a Turbo 350 transmission or one of the later-style overdrive automatics like a 700R4, etc. You'll need to fabricate engine/transmission mounts, and deal with things such as the enclosed driveline, rear end, etc. You'd be better off finding an insert-bearing 235 engine and installing it with the original transmission. There would be a lot less fitting and adapting involved with that swap! A Powerglide from a 55-61 V8 engine would bolt up to the late-model 6-cylinder, but it still won't solve the driveshaft adapting probl;em. Your car has an enclosed driveline, and the mid-50's transmission is made for an open driveshaft. Jerry
#40837 12/08/2004 12:33 AM | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | No one has stated it explicitly , so I will: The V-8 which came out in 1955 had a different bellhousing pattern than the 6 cylinders of the day. In 1963, a new line of sixes appeared which used the V-8 pattern. So, the 216, 235 and 261 (as well as the GMC 228,248,256,270,302) shared the old pattern while the 'new' sixes (230,250,292) use the same pattern as the V-8. | | |
#40838 12/08/2004 1:06 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I once owned a '62 Chevy that was factory with a 283 and cast iron powerglide. There was an adapter ring between the transmission and the motor, and I understood there was a different ring for the sixes.
Could it be that finding a V-8 type adapter ring from an early cast-iron powerglide would allow using a 230/250/292 with the early transmission?
I've no idea, and no intention of doing such a thing, but it might Ben's problem...
#40839 12/08/2004 8:38 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | so, a 55-62 six would be the best swap then?
Benjamin P Lujin
#40840 12/08/2004 10:29 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Yep....that would work the best. Do you still have the closed driveline rearend? | | |
#40841 12/09/2004 10:07 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 |
Benjamin P Lujin
#40842 12/09/2004 10:09 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | should i try selling the babbetted bearing engine, or would it just be a waste of my time?
Benjamin P Lujin
#40843 12/09/2004 10:48 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Well....I'm a saver...I don't throw anything away....someone might want or need it.
Offer it up for sale or free on the swap meet or E-bay....someone will take it off your hands. | | |
#40844 12/09/2004 10:49 PM | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Put it on Ebay in "as is" condition, with an honest report on what you think is wrong with it. You might be surprised what it will bring. Jerry
#40845 12/19/2004 7:27 PM | Joined: Dec 2004 Posts: 7 Junior Member | | Junior Member Joined: Dec 2004 Posts: 7 | wound up getting a 235 out of a 54 truck. it's almost installed now.
Benjamin P Lujin
