4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
Just removed my Bellhousing from my 235 and see the pivot pin that is in the bellhousing has two grooves worn in it from the shift linkage bellcrank. Can this pin be replaced or repaired somehow?
Still trying to get ole Betsy back on the road.
Craig,
Don't quote me on this, but I think it is simply screwed into the bellhousing.
Stuart
Riding in the Passing Lane
It will be hard to find a good one. You can take it out & weld up the grooves & grind it back. I just use acetylene with brass rod to build things like that but someone good with a Mig could easily do it.
1972 Chevy c10 Cheyenne Super
I recall that it is pressed-in (in 1954); however, a different style clutch-housing was used in earlier years. But, just as Stuart cautioned, don't quote me on this (I did this several years ago).
On my '49 housing it was screwed in. There's an NOS one up on EBay for sale right now.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
49 Geezer,
What is the eBay item #. I am interested in seeing if it fits the 54 and later bell housing.
Tim
Tim, Arlyn has my 54 bellhousing and it is out right now. You may ask him if that stud was pressed in or screwed in.
Tim,
Is it legal to mention item # 120253829225. smile
Stuart
Stuart,
That is the clutch fork pivot ball. It is screwed into the inside of the clutch housing.
"shift linkage bellcrank"
I think that Craig/49 Panel is referring to the pivot for the shift linkage that is on the outside of the clutch housing on the driver's side. The 3-speed linkage rods attach to brackets that pivot on that "pin". This pivot pin is not needed on a 4-speed. Of course, as is usual, I could easily be wrong.
Tim
Tim,
Ahhaa. I guess that round ball wouldn't work to well for a bellcrank pivot...sorry folks. blush
Stuart
Tim is right. I'm refering to the one on the outside of the bellhousing. I also didn't mention that my engine is a 54 so the trans and bellhousing my also be. It looks pressed in to me. The 54 is my spare engine. I have to check the one in the actual 49 truck to see if it's in better shape or an earlier bellhousing with the possibility of a screw in pin providing the information all you bolters have provided so far. Right now I'm thinking it is also a 53 or 54 so it may be the smae anyway.
You should be able to sleeve it and bore the bellcrank to match. Measure the o.d. where it's not worn and subtract .001"-.002" to determine sleeve i.d.
You Tube
Curt B., Thanks for the solution. I didn't think of that. Hopeflly it won't be too hard to find a sleeve.
Any piece of pipe can be a sleeve. Find somebody with a lathe. High school machine shop maybe? Good luck.
You Tube
