7 members (Otto Skorzeny, GMCJammer51, Phak1, TGP, DadsFirstPickup, Wayne67vert, carbking),
120
Mod | | | Forums66 Topics128,049 Posts1,055,682 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40707 07/12/2004 7:15 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | This is on my BMW. I was trying to replace the ball joints this weekend and I couldn't get them to press out of the control arms. (I have a 12.5 ton H frame press) I even blew one of the joints out the back. Is there a proper procedure? I ended up just taking them to a machine shop because I didn't want to hurt myself or the rather expensive control arms.
The joints were rather floppy after 165,000 miles of rather spirited driving. The car is just too fun and reliable to get rid of, though.
#40708 07/13/2004 12:10 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | There's a tool called a balljoint press, it has sleeves of various sizes. the sleeve fits over the joint so you are pressing against the joint body and not the ball stud.Perhaps a short length of pipe will work. BMW has the tool, most likely the price of a small Japanese car  | | |
#40709 07/13/2004 12:48 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | When I switched out the ball studs from my AD steering arms, I found they had been swaged into the arms. While the bore for the ball stud is straight, the very bottom is chamfered. If the chamfer is not reamed out, the stud will not come out. I drilled a hole on dead center with a series of cobalt bits starting with a pilot on dead center then up to 3/8." The ball stud was about 1/2." At the last, I used a rotary file on a die grinder and slightly chamfered the bottom of the hole in the arm. Then the old ball stud punched right out without a struggle.  Just make sure you don't overdrill the hole and it should work smooth. Perhaps the dam thing is threaded in. If so, nevermind.  | | |
