| | | Forums66 Topics128,050 Posts1,055,754 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40656 09/19/2004 9:06 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I have a '45 half ton with an original 4sp. transmission. Upon reading my shop manuel, it says the tranny holds 5 1/2 pints of fluid. Am I correct to assume that topping it up level to the fill plug is the same thing? :rolleyes: | | |
#40657 09/19/2004 9:19 PM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | That method's worked on just about every manual trans I've ever serviced. Just be sure not to get the lube level up to the point where the input and output shafts are submerged, ot it's almost impossible to avoid a leak. Jerry
