7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1 New Guy | | New Guy Joined: Sep 2006 Posts: 1 | Hey gang.. was wondering if anyone knew a disk brake kit i can pick up for my new addition.. 65 Chevy C 10 Id put up a picture of it but i dont know how.. ( smirk ) Thanks in advance..
J.
insert foot in mouth
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I do not work for these people and I have not used their kit, but I have emailed and messaged people who have. http://www.earlyclassic.comIt is not cheap, but I was told that they include every little nut, bolt and fastener that you need. I was also told very positive things about the quality of the parts. They are also known for having very useful tech support people. Their kit is based off later model chevy truck brake parts, not car brakes. a few of the guys over here: http://www.chevytalk.org/fusionbb/showforum.php?fid/58/have used the kit. Good luck... -W | | | | | Joined: Jan 2007 Posts: 16 New Guy | | New Guy Joined: Jan 2007 Posts: 16 | The easy thing to do is to get a set of 73-87 spindles from the junkyard or from an online source. You can then buy all the parts you need (rotors calipers, etc) from your local parts house much cheaper than buying a full kit, just don't forget to change out your ball joints to match the spindles. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | www.classicperform.com carries everything you need...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
