6 members (ranchojuan, MikeStone1953, Biermann, Philipj, Peggy M, Wayne67vert), 71 guests, and 2 robots.
Topics128,153
Posts1,056,849
Members48,456
I have a 1966 Chevy 250 and want to put a 1988 T-5 in it. I have the original bellhousinga and flywheel for it.
Could somebody tell me what year and model vehicle does the clutch and pressure plate and throwout bearing have to come from?
Thanks, Mike
I have a similar set-up, but with a 1971 350 and 88 T-5. It took my parts shop a couple tries to get the right clutch-PP kit, and it all boiled down to the number of splines on the input shaft. Walk in with as much accurate info as you can about the trans, but be sure to count the splines on the front.
Nice looking 57 truck. Which bellhousing and what size flywheel did you use. I,m going the same route with my 57 big window. Thanks, coupe 30
