1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
Apprentice
Apprentice
I have a 63 C60 with a 2 speed rear axle. I am replacing the wheel bearings and there is a spacer in the hub about an inch wide between the outer bearing race and the splined part of the hub. I need to replace this because it is damaged and I don't really know what it is called so the guy at the parts store can look it up. Anybody know what the proper term for it is or maybe have a part number?
3B Offline
Hy Adam Ogle, it looks like the part you are looking for is called a spacer, 63 axle 3703705 is the part number, not for heavy duty axles 4 7/32" o.d., hope that helps
Apprentice
Apprentice
Thanks 3B I knew you would come through for me with a part number I really appreeciate it.
