0 members (),
72
7
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | what would be the best rearend ratio to use with a powerglide bolted to a 230 i6
-daily driver -driven on freeway -230 with clifford rebuild kit,264 cam and 4barrel 390 carb
thanks -chris- | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ghettobug, you didn't tell us what vehicle this setup is in, rear end ratios for trucks are limited. If you want the best mileage, the lowest ratio [numerically] will provide that, if you haul or tow, you want a higher ratio. Let us know what truck we're talking about, and we can probably find out what ratios are available, hope that helps. | | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | the truck is a 1964 chevy c10 short fleetside. i will not be towing anything with this truck. i will also be driving on the freeway daily.
thanks -chris- | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'd think interms of 3:36 or thereabouts, certainly nothing higher (numerically lower) for a 230. That would approximate what GM put in a car with that engine. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It also depends on tire size. I'm with Moneypit, something in the 3.55 ratio. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | thanks for the help guys
thanks -chris- | | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | where could i find a 3.36 or 3.55 ring and pinion?
would a 55-62 3.38 ratio work ok? i was just looking at the jim carter catalog.
or would i be better off keeping the 3.73 ratio?
