| | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 33 Apprentice | | Apprentice Joined: Jan 2008 Posts: 33 | I have a 63 C60 with a 2 speed rear axle. I am replacing the wheel bearings and there is a spacer in the hub about an inch wide between the outer bearing race and the splined part of the hub. I need to replace this because it is damaged and I don't really know what it is called so the guy at the parts store can look it up. Anybody know what the proper term for it is or maybe have a part number? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Adam Ogle, it looks like the part you are looking for is called a spacer, 63 axle 3703705 is the part number, not for heavy duty axles 4 7/32" o.d., hope that helps | | | | | Joined: Jan 2008 Posts: 33 Apprentice | | Apprentice Joined: Jan 2008 Posts: 33 | Thanks 3B I knew you would come through for me with a part number I really appreeciate it. | | |
