| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40580 07/19/2003 3:46 AM | Joined: Jul 2003 Posts: 22 New Guy | | New Guy Joined: Jul 2003 Posts: 22 | I have an all syncro three speed tranny that I want to use but like the closed driveline--no spring wind up! I also have a full floating R/E from a 3/4 ton that I want to use. any ideas what the ratio would be in an early 50's 3/4 ton 3 window GMC? Roar
Greasy Thumbs
#40581 07/19/2003 4:40 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If it is from a 3/4 ton, it will be most likely a 4:56 ratio
