4 members (Materman, fonz8261, cmayna, Shardean), 80 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
1 Offline
anyone have the front track width for a 54' chevy 5700 coe? thanks. grin
3B Offline
Hy 10 micron, My truck salesmans data book says 60 1/4", hope that helps.
1 Offline
thanks! that number had me at a panic when i confirmed it. the reason being is the GMC fwd motorhome track width is 75.28 but then after i looked the overall fender width is 77.56 so that leaves 1" on each side so all should be fine.
That means you'll want to check the fit in the fender wells lock to lock on the steering before deciding on how high to mount the body on that frame...
1 Offline
should have plenty of room to play with considering the gmc motorhome has 16" wheels vs the stock 20" ones.
