| | | Forums66 Topics128,091 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 23 Apprentice | | Apprentice Joined: Apr 2008 Posts: 23 | The manual says take out the 5 screws and the panel should come out. I took out the screws and can't even pry it out. Is there a trick or am I missing something? The speedo didn't work on the maiden voyage today and I discovered it wasn't hooked up. The temp and gas gauge don't work either so I figure I'll look at them when (if)I get it out. Does the cluster need to tilt or come out some special way, like bottom first? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | 60-63 dash panels seem to be a problem. I have problems with my 63 every time I take it out. Sometimes a good whack on the back will jar it out enough to work it the rest the way. From what I've been able to tell it seems to be the clip-on nuts for the screws hang up on the panel. Try slipping some putty knives in where the screws were removed and see if that helps.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | same problems on the 64-66. just be gentle so you dont ddamage the bezel.
"you can't fix stupid"
