6 members (BC59, klhansen, UtahYork, homer52, HelmutVonSchet, wilbur53), 125 guests, and 0 robots.
Topics128,113
Posts1,056,618
Members48,450
#399674 04/08/2008 9:58 PM
What is the best lubricant for my 4 speed manual?
Thanks.
jdl Offline
90 weight gear oil, but you might want someone else to second that because I don't know very much about this kind of stuff. The 90w is what I was told to use.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Riding in the Passing Lane
I'll second it. Most of it comes in 80/90 weight. Either will work fine.
1972 Chevy c10 Cheyenne Super
I'll third it. I'm partial to the Lucas full synthetic myself.
Bill Burmeister
The new process transmissions used ATF to help mileage, dealer mechanics put 30wt compressor oil (non detergent) in them at service. I used 50wt racing (non det) in some, worked good.
use multigrade, 70-140 or 70-90 so it is as thin as possible for milage, if you trans whines like mine does, a little lucas will keep the oil climbing the gears and dampen the noise. Lucas oil stabilizer rocks for old trucks.
64 & 66 GMC long fleetside 4x4
Cartwright, OK
I remember my T-5 in my Mustang called for ATF so I wasn't sure. I have some 80/90 gear oil I will use.
How does the Lucas oil stabilizer help the 80/90?
Just in case, I should say that I am putting the 80/90 in the Transfer case and axles, is that fine for those as well?
Thanks for the responses!
160w oil is what is recomended in 4speed truck trannys from Chevrolet. The problem is finding it in Canada. Mbile oil carries it but you may have to buy in 5gal pals. It's also known as 600w steam or cylinder oil. Never use a detergent oil in an old tranny. Especially if a 4 speed non-synchro. This information is from the original Chevrolet service manual.
Keith and Kim
1942 Chev 3/4-Ton Flatdeck in the Gallery
Victoria, BC, Canada
