| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 9 New Guy | | New Guy Joined: Feb 2008 Posts: 9 | anyone know whats involved in reaming out the spindle bushings on a 1948 1.5 ton loadmaster. thanx for any help | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy alfaulk, new bushings once installed need to be reamed to fit, the factory reamers [Kent-Moore I believe], were fixed sizes with a lead in taper. The reamers were long enough to ream both bushings at the same time. Actually the reamers had two cutters seperated by a solid shaft. The tools are rare, I have a couple of adjustable reamers with long pilots, with a taper cone for centering the pilot in the bore not being resized, I would suspect that is how a machine shop would perform the operation today, hope that helps | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You pretty much have to take them to a machine shop. Most of them will do it with a piton pin machine. I tell them to fit them a little snug though. They should not fall through but push through with your thumb. It seems the shops want to fit them a little loose. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
