3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Barn find 1940 Chevy Sedan, showing 63K original miles. 216 engine in place and appears to be in fine shape. However, the only #'s I could read on the engine were as you'd expect, on the pad behind the distributor: 3493I60
Don't appear to be original #'s, or at least anything I can match up, but curious to see if anyone else has any definitive information.
Would make the find a bit more exciting to know it was likely an original block???
Thanks in advance for the help. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Inliners site list the following numbers: 1940 serial # 2697268-3665902 which would include your number. The actual block cast # for all 1940 blocks would be 839132.
Drew
