2 members (Otto Skorzeny, baldeagle), 114 guests, and 2 robots.
Topics128,037
Posts1,055,467
Members48,424
Jed
Offline
Barn find 1940 Chevy Sedan, showing 63K original miles. 216 engine in place and appears to be in fine shape. However, the only #'s I could read on the engine were as you'd expect, on the pad behind the distributor: 3493I60
Don't appear to be original #'s, or at least anything I can match up, but curious to see if anyone else has any definitive information.
Would make the find a bit more exciting to know it was likely an original block???
Thanks in advance for the help.
Inliners site list the following numbers: 1940 serial # 2697268-3665902 which would include your number. The actual block cast # for all 1940 blocks would be 839132.
Drew
