1 members (2-Ton),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40433 01/03/2004 5:15 PM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | would like to stay with a GMC motor the 1955 1/2 ton has a 6 cly I think it is a 248 ( the chart of vin #s says 2 nd serries 55 with 248 my vin number 102-cy-1587) what other GMC motors will bolt up to my 1955 hydramatic what years ? which is the best for every day use and will go todays speeds. thanks for any info. Bill
Bill 1951 3/4 ton 5 window pick up 1955 GMC 1/2 ton longbed automatic
#40434 01/03/2004 5:22 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 248 won't limit your highway speed, your rear-end gear ratio will. I know that the '54 hydramatic has the same low gears as the manual tranny trucks. I don't know about '55. Anyway, the 248 should be sufficient if you use a higher gear ratio. | | |
