| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I'll be testing the vacuum on my 235 next week. Can anyone tell me what to expect? The engine is running great. My mileage is good and the low rpm idle is very smooth since I converted to HEI. My new booster for the disc brakes requires at least 18 inches - that's why I'm asking. I'll be plumbing the new hard line next week also and then project will be finished. As long as I have enough vacuum  | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bigmacdaddy,
I have read that you can expect between 17 and 20 inches of vacuum with a engine that is properly tuned, equipped with a stock cam and in good mechanical condition. It sounds like your rig fits the bill.
Stuart | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You will also get more vacuum out of the engine when coasting and in gear than you will get at idle.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | For all interested parties, I have to disagree with some of the information contained in the link provided in the earlier post. So, taking each condition separately:
Normal engine: Information given is good- no question there.
Steady low: Ok, but there are other causes for that condition.
Steady very low: Ok, but other indications will be far more prevalent than just low vacuum- sluggishness, backfiring (intake or exhaust), hard starting, etc. If I saw that indication in the shop, I would use it only to substantiate the suspicion of valve timing- but if valve timing is off enough to cause that low level of vacuum, most often the ignition timing will be off as well- distributors are camshaft-driven.
Steady, extremely low: If there is an intake leak large enough to cause that level of manifold vacuum, the fuel mixture will be too lean for the engine to continue running. If by chance an engine were still running with that large an intake leak, no matter where, the speed would be so erratic that the vacuum gauge would fluctuating severely- half-scale or so. Not good information.
Needle rhythmically drops: Ok, but you will seldom see more than 1 1/2 inches of mercury drop with a compression misfire, and the drop depends on the compression loss and engine speed. An ignition misfire causes the condition described, but the drop is seldom more than 1 "Hg. An intake manifold leak affecting one cylinder more than others will give a similar vacuum indication, but will diminish as engine speed increases. Ok with the sticking valve idea.
Drops to 0, then rises: The indication is correctly described, but the stated causes are pretty shaky. With a sudden full-throttle acceleration, the vacuum shown by a gauge will reach zero, if for no other reasons than momentum of the gauge mechanism, spring tension of the internal tube, and slow acceleration of the engine- some accelerate faster than others when the throttle is snapped fully open. Also, some gauge movements are heavily damped to prevent immediate responses to large changes, so gauges from two manufacturers may give different readings. The possibilities given are technically valid, but you will not see the results with an engine that is not loaded. If you run an unloaded engine long enough at full throttle to reach 4-5 "Hg, you risk catastrophic failure. Those indications would be valid if the engine/vehicle is loaded with a dynamometer, but don't try that in your driveway with no load on the engine. An exhaust restriction doesn't show up with that check.
Needle wavers rapidly, 10-20 "Hg: Not likely for the causes given; that level of fluctuation is showing the "death thoes" of and engine that is only a few revolutions from stalling. The possibilities cited will cause the same indications as compression loss/compression misfire, although the indications may be intermittent or erratic. The slow valve opening cited is incorrect- remember valves open under camshaft/lifter/rocker arm force, then close under the lesser spring force, so slow closing, not slow opening. The irregular wavering described with that same indication is somewhat all right, but higher speed above 1200-1400 RPM will diminish the indications to the point of being invisible.
Drifts at idle, stabilizes at high speed: No. Drifting at idle speed represents a fuel mixture situation- rich or lean are similar. The burned valve causes a compression misfire that does, in fact, diminish as speed increases; at low speed, compression misfire will appear as the regular, rythmic drop. See the condition described in "Needle rhythmically drops." It can't be both ways- and it isn't.
Needle jumps 2-5...: That is a normal indication. The return to "normal" is dependent on the speed of deceleration- a loose engine decelerates slower than does a tight engine. An exhaust restriction does in fact cause back pressure. In that state, air doesn't exit the engine properly, so air doesn't enter the engine in the proper quantity, therefore, lower manifold vacuum rather than higher vacuum. And under deceleration, there is less air going into the engine, so there is less air exiting the engine, so exhaust restriction becomes less of an effect. High air flow, large effect from restriction; low air flow, low effect from restriction.
Needle does not jump...: Technically correct, but if piston rings are worn to that extent, the likely indication will be a heavy cloud of exhaust smoke that is a much better indicator of ring/cylinder wear than is a vacuum reading. But this is technically correct, just don't overhaul your engine based on that indication. A wet compression check is a much better indication of ring/cylinder wear.
Not mentioned: Exhaust restriction will show up as a declining vacuum level as engine speed increases. Holding the engine at a given speed will stabilize the vacuum at what ever level exists for the throttle position and the degree of restriction: wider throttle, more restriction, lower vacuum level.
There can be more said about vacuum checks.
Harvester
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | So I guess all this means my new boosted disc brakes will only work well when the engine does. That isn't something I considered when I made the decision to go to discs and a booster.
Live and learn. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bigmacdaddy,
I guess I didn't see the BAD news on this topic. Your booster should function fine. Buy a little vacuum gauge used for tuning from a local big box and hook it to your wiper tap on the intake.
Run the gauge into the cab and drive around a bit.
I'll bet you have more than enough vacuum to make your brakes work great.
Stuart | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Your booster should also have a check valve on it's input to retain booster vacuum even under heavy acceleration. This is the standard set up on most vehicles so you shouldn't have any problems. Since you're running HEI I assume you're on 12V so you could also get a vacuum pump instead of using engine vacuum. Also a fuel/vacuum pump may get the job done. They were originally used for wipers. I don't have one so I don't know how effective they are. Good luck!
Ed
| | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | You may be able to add a storage tank that will help. I bought one at a swap meet but I have seen them at Summit for about $50. Mostly the guys with the lumpy cam V-8s need them.
I ended up not going with the booster. I found another way to increase the pedal ratio from 5:1 to 6:1 so I using a manual brake master from CPP. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Find an empty 15-lb. Freon tank and bracket it somewhere out of sight, like under the bed, then run a big vacuuum line to it, 1/2" diameter or larger, by cutting the original shutoff valve out and installing a grommet. That's how the old Hydrovac units on big rigs stabilized the vacuum, and I can't think of any modern booster at the master cylinder that would require more vacuum than a Hydrovac. Jerry
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Thanks Jerry, that will definately be a last resort sort of thing. I am optimistic that things will be fine. In terms of vaccum, how will a mildly built, 261 stroker compare? That's the motor that is going in the truck next winter. | | |
