0 members (),
50
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Does any one know where I can buy new castle nuts for my spindals . My 52 1300 nearly lost a wheel.I would prefer a Canadian supplier but so far I have had no luck.I think the nut is a 3/4 national fine.US or CDN if any one has a sourse would be appreciated. Thanks Jeff | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Should be able to get them at the parts store. GM used that style castle nut well into the '80s.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy coolchevy, Lordco should be able to get you Papco part # 093-026, 3/4"X16 t.p.i., 1 1/8" across the flats, and 13/16" thick, hope that helps. | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | thanks you guys. I called Lodrco this am and they said they didn't have them. Maybe the guy was green. Thanks for the Papco nunmber . I'll call them tomorrow . I'll let you know . Or I'll call the local GM /Chevrolet dealer. Jeff | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Go to an aircraft maintenance company or even a good hangar. They will have them. | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | well I found a supplier in Nanaimo and they sent me 6 for $1.12 each. However they sent them via expedided courier from Vancouver, thats across The Straight of Georgia, for a grand total of $24.34. And guess what ? the thread count is 12 threads per inch. Not the 16 that I ordered. Idiots!!! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | coolchevy,
In conventional fasteners, there is no 3/4 X 12 TPI configuration. 3/4" utilizes 10,16 or 20 threads per inch.
This isn't to say they don't make a 3/4 X 12 thread, but it must be something weird and special. Are you sure you measured correctly. Maybe the end of the spindle is banged up...pretty common.
Stuart
| | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | hey Stuart, I count 16 threads per inch inside my old castle nut which is what I wanted. The nuts they sent I count 12 . Could be ten ,however they are a coarse thread. thanks Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Jeff - I prolly have some in the stash or on one of the numerous TF axles here, I could check, if you have reason to get up to Courtenay
Bill | | |
