0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#403062 04/16/2008 8:11 PM
Well it finally happened. My circular heater core is no longer repairable. There are no replacements except at Jim Carter and he wants $225.00 just for the core and I still would have to pay to have my tanks and copper put on. another 100 bucks.I guess its obvious that unless I can find NOS (ha) or another used one that is any good I will have buy an aftermarket one such as the one Classic Chevy has.($160.00)I would like to keep "RT" factory.
Suggestions?
Kevs57 #403089 04/16/2008 9:14 PM
I used the JC core and it worked out really well. Sometimes it just costs a lot of money to get over the hump! What I did find remarkable was how quickly it warms the cab up.
If you are into an at home repair, you can pressurize it with couple of pieces of heater hose and some valve stems clamped in the ends. Use a bicycle pump to add a couple of pounds and then immerse it in water. After finding the leak, pull the fins or webbing off around the leak. This leaves a nice salmon colored clean copper exposed. Do the repair and retest. I did this and it worked until it got warm and then it leaked again.
1951 1 Ton Completed
Kevin Is it the round type like in the 1954 3100????
If you keep an eye on ebay you can always find Heaters that are ratty but you may find the heater core is good and repairable or try to get he old one repaired... Peter
Keep checking on line. An NOS one just sold on ebay a couple weeks ago.
Bruce
My Trucks
Stuff I Collect
Hey, good timing! Nothing like having all Spring, Summer and Fall to find a good core.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #403357 04/17/2008 10:23 AM
theres 2 or 3 on there right now for 20 or 30 bucks
