3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#403123 04/16/2008 11:01 PM
th
Offline
running a 350/350 combo.engine has a mild cam,HEI dist.with vacuum advance,holley 4-barrel which i just cleaned out.truck hesitates off the line and surges when running down the road.had it timed to 10 degrees at idle and tried to set it between 28-32 fully advanced but could not get it under 40.checked for vacuum leaks,could'nt find any.HELP!
th #403138 04/16/2008 11:20 PM
Riding in the Passing Lane
You must time it with the vacuum advance disconnected. You should get about 34 degrees full advance without the vacuum. The vacuum will add a few degrees at cruising speeds for economy. I find some engines surge like that with the vacuum advance. Try driveing it with the vacuum disconnected & plugged. You may have to get an adjustable vacuum chamber & limit the amount of advance. Usually an automatic trans works best with the advance hooked to ported vacuum.
1972 Chevy c10 Cheyenne Super
