1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | Well it finally happened. My circular heater core is no longer repairable. There are no replacements except at Jim Carter and he wants $225.00 just for the core and I still would have to pay to have my tanks and copper put on. another 100 bucks.I guess its obvious that unless I can find NOS (ha) or another used one that is any good I will have buy an aftermarket one such as the one Classic Chevy has.($160.00)I would like to keep "RT" factory.
Suggestions?
Kevin | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used the JC core and it worked out really well. Sometimes it just costs a lot of money to get over the hump! What I did find remarkable was how quickly it warms the cab up.
If you are into an at home repair, you can pressurize it with couple of pieces of heater hose and some valve stems clamped in the ends. Use a bicycle pump to add a couple of pounds and then immerse it in water. After finding the leak, pull the fins or webbing off around the leak. This leaves a nice salmon colored clean copper exposed. Do the repair and retest. I did this and it worked until it got warm and then it leaked again. | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Kevin Is it the round type like in the 1954 3100???? If you keep an eye on ebay you can always find Heaters that are ratty but you may find the heater core is good and repairable or try to get he old one repaired... Peter | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Keep checking on line. An NOS one just sold on ebay a couple weeks ago.
Bruce | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Hey, good timing! Nothing like having all Spring, Summer and Fall to find a good core. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | theres 2 or 3 on there right now for 20 or 30 bucks | | |
